PythonCaller read list error
  • Nov 22, 2024 1:00 PM UTC
  • 125 views
asablomberg
Forum|alt.badge.img+8
I want to loop through the list ‘attribute’ in a PythonCaller and change some values, but I get an error. Line 34 is the for-loop.
  File "<string>", line 34, in input
Python Exception <TypeError>: 'NoneType' object is not iterable
Can you see the error?
    def input(self, feature: fmeobjects.FMEFeature):
feat = feature.getAttribute("attribute{}.attribute")
for obj in feat:
if "fme_varchar" in obj.fme_data_type:
Best answer by david_r
Unfortunately you cannot read an FME list like that, you have to reference every child attribute.
Try something like:
names = feature.getAttribute("attribute{}.name")
data_types = feature.getAttribute("attribute{}.fme_data_type")
attributes = zip(names, data_types)
for (name, data_type) in attributes:
if "fme_varchar" in data_type:
# Do something
print(f"Attribute '{name}' is of type '{data_type}'")
  • Nov 22, 2024 1:15 PM UTC
Try something like:
# Do something
asablomberg
  • Nov 25, 2024 8:54 AM UTC
Thank you! Here is my result. Any more input and comments are welcome. :) Is there maybe a better alternative than using the loop counter ‘i’?
delimiter = ""
i = 0
#extract only numbers from datatype
temp = re.findall(r'\d+', data_type)
res = int(delimiter.join(temp))
# if column name longer than name, alter datatype
if len(name) > res:
res = len(name)
new_data_type = "fme_varchar(" + str(res) + ")"
feature.setAttribute("attribute{%d}.fme_data_type" % i, new_data_type)
i = i + 1
self.pyoutput(feature)
