Python Libraries not available?
  • Mar 28, 2025 4:08 AM UTC
  • 137 views
cbrien
Forum|alt.badge.img+3
Hi all,
I’m attempting to create a python script to encrypt a file for transfer to a bank.
We need to be using PGP encryption, and as I understand the only way to encrypt using FME is by way of python.
Having only recently joined the organisation, I was not here when the installation of the latest Form and Flow was undertaken, (otherwise I would have advised that the Flow installation 2022.1.1, should at least match the Form version 2023.2). But that’s only part of the problem I believe.
First, I would like to attempt to figure out if the libraries are available from a Form workspace running on my desktop.
When I check the INTERPRETER settings in the Options menu, it appears I cannot change or make reference to any alternative path.
So far I have had very little luck, and would like to know if anyone has
  1. a simple python script that can run in a workspace PythonCaller/PythonCreator that will provide a test (so far the script produces an error any way I attempt to write to the log). I must admit, I am at best a beginner with Python but use all manner of online resources to find solutions.
  1. a method of trolling through the installation of FME to find the answer
Any help would be very much appreciated.
Cam
  • Mar 28, 2025 4:04 PM UTC
You’re right about having to use Python for this, FME cannot do PGP encryption natively, as far as I now. Your first issue is indeed that your Form is much more recent than your Flow, which isn’t supported: https://support.safe.com/hc/en-us/articles/25407441075469-FME-Versions-and-Workspace-Compatibility
Having taken care of that, you will have to install the required Python modules on both Form and Flow, as its somewhat different:
https://docs.safe.com/fme/html/FME-Form-Documentation/FME-Form/Workbench/Installing-Python-Packages.htm
https://docs.safe.com/fme/html/FME-Form-Documentation/FME-Form/Workbench/Importing_Custom_Python_Modules_FMEServer.htm
  • Mar 28, 2025 4:57 PM UTC
An alternative to Python might be to use a PGP command line utility using the SystemCaller transformer. That way you probably won’t have to write any Python at all, if that’s not your thing...
cbrien
  • Mar 31, 2025 7:05 AM UTC
Thanks David,
We’re going to try an install of gpg with the command to invoke that instead of the Python method. Unfortunately, I will not get around to an upgrade until a few months’ time. (still planning it).
If we, however, take to a Python solution, those articles and advice are well received.
Many thanks,
Cam Brien
