Python getNamedConnection failing to retrieve connection by Name (str)
  • Jan 15, 2025 4:10 PM UTC
  • 135 views
_fabian_
Forum|alt.badge.img+5
I’m trying to retrieve a WebConnection using the FMENamedConnectionManager in a PythonCreator as described here.
Content of the PythonCreator:
import fmeobjects
import fmewebservices
class FeatureCreator(object):
def __init__(self):
fmewebservices.FMENamedConnectionManager.getNamedConnection('SAP S4')
def input(self, feature: fmeobjects.FMEFeature):
pass
def close(self):
pass
The execution fails with the Error
Python Exception <TypeError>: descriptor 'getNamedConnection' for 'fmewebservices.FMENamedConnectionManager' objects doesn't apply to a 'str' object
even though the documentation clearly states that the first parameter must be a string object (connectionName (str))
What am I doing wrong?
Best answer by david_r
Try invoking the FMENamedConnectionManager as a class instance:
fmewebservices.FMENamedConnectionManager().getNamedConnection('SAP S4')
See also:
  • Jan 15, 2025 5:09 PM UTC
See also:
_fabian_
  • Jan 16, 2025 7:17 AM UTC
Thanks, this worked. The documentation was a bit misleading in this regard. ​
