Python caller gives no output
  • Apr 22, 2024 8:40 AM UTC
  • 6 replies
  • 533 views
bertbooneman
Participant
When i use the python caller i get a translation successful, but it gives no output.
I'm not very good at python, so do any of you have an idea what i did wrong?
j.botterill
Forum|alt.badge.img+69
  • Apr 22, 2024 8:43 AM UTC
One tip might be to capture some of the Python processing into your FME transaction log https://support.safe.com/s/article/logging-with-python-scripts
In a PythonCaller (or PythonCreator) transformer, messages are added to the logfile with the FMELogFile object, which is part of the fmeobjects. You need to create a logger object: logger = fmeobjects.FMELogFile() and then you will need to send messages to the logger: logger.logMessageString("Hello I am Logging Now")
jkr_wrk
Forum|alt.badge.img+37
  • Apr 22, 2024 8:48 AM UTC
On what row did you type:
self.pyoutput(feature)
hkingsbury
Forum|alt.badge.img+73
  • Apr 22, 2024 9:08 PM UTC
As @jkr_wrk mentioned, you’re missing
The purpose of this line is to output the resulting features. At a guess, you’d want this to be on line 25, indented to the same level as line 18.
Having it here will output every feature you input into the pythoncaller
shelton786
BANNED
  • BANNED
  • Apr 23, 2024 6:14 AM UTC
Hello,
If your python script completes without errors but lacks output, check for print statements to ensure results are displayed. Verify input handaling and run the script interactively for step by step debugging. Look for silent errors in the console and test with sample data to confirm expected behavior.
geomancer
Forum|alt.badge.img+71
  • Apr 23, 2024 7:39 AM UTC
I'm no python expert, but these lines look very strange:
y = 'true' if not feature.getattribute('Score 6 t/m 18') else 'false'
if "bebouwing" in x and y == "true":
I'm pretty certain this will not do what you want it to do.
jkr_wrk
  • Apr 23, 2024 8:28 AM UTC
I did not look into all the PythonCaller code before.
FME is in principal a NoCode application to do all the things you want to do. It looks like you don't have much experience in coding in Python or using Python in FME.
The function you are writing is very easy to do using 1 or 2 transformers, so it looks like you should keep away from the PythonCaller.
Except when your only goal is to learn to use the PythonCaller in general because you are certain that there are things you want to do that FME can't do with basic transformers.
