Python Caller: appendLine
  • May 23, 2018 2:53 PM UTC
  • 39 views
I use PythonCaller to reconnect lines that were splitted before, if some conditions are met.
#self.LastFeature --> a line I collected before
#GivenFeature --> a matching line that I want to connect to first feature
self.LastFeature.getGeometry().appendLine(GivenFeature.getGeometry())
Both ends meet, but the "LastFeature" doesnt change its Geometry.
Can you explain, why and how to solve this? Do you have a link or search words?
Thanks in advance.
Andreas
  • May 23, 2018 3:03 PM UTC
You need to set back the geometry after having modified it.
Try something like the following:
geom = self.LastFeature.getGeometry()
geom.appendLine(GivenFeature.getGeometry())
self.LastFeature.setGeometry(geom)
  • May 23, 2018 3:10 PM UTC
@david_r
Thank you very much for the fast answer, this works fine.
