Python and FME Server - Unprocessable Entity error
  • Apr 7, 2017 11:11 AM UTC
  • 6 replies
  • 249 views
oscard
Forum|alt.badge.img+23
Hi.
I want to run a workspace using the Python script I have pasted here. But everytime I run it, I get the following error:
HTTP Error 422: Unprocessable Entity
My Python version is 2.7.
FME Server 2016
Thanks for any help provided!
import urllib2
import json
SERVER_URL = "http://100.100.100.100"
REPOSITORY = "MyRepo"
WORKSPACE = "First%20Test.fmw"
TOKEN = "ddddddddddddddddddddddddddddddddddddddddddddddddd"
# Set up the published parameters as object
params = {
    "publishedParameters" : [
            "name" : "path_1",
            "value" : "C:\test1"
            "name" : "path_2",
            "value" : "C:\test2"
url = '{0}/fmerest/v2/transformations/commands/submit/{1}/{2}'.format(SERVER_URL, REPOSITORY, WORKSPACE)
# Request constructor expects bytes, so we need to encode the string
body = json.dumps(params).encode('utf-8')
headers = {
    'Content-Type' : 'application/json',
    'Accept' : 'application/json',
    'Authorization' : 'fmetoken token={0}'.format(TOKEN)
# This will use POST, since we are including data
req = urllib2.Request(url, body, headers)
r = urllib2.urlopen(req)
print('Request status: ' + str(r.status))
resp = r.read()
resp = resp.decode('utf-8')
resp = json.loads(resp)
if r.status == 202:
    print('Job ID is {0}'.format(resp['id']))
Best answer by david_r
On second thought you don't need the urlencode().
There's possibility that the backslash in your path names is causing problems. Try using forward slashes:
params = {
            "name" : "path_1",
            "value" : "C:/test1"
            "name" : "path_2",
            "value" : "C:/test2"
For reference, return code 422 means "The request was well-formed, but cannot be performed due to semantic errors." If you still get the error, make sure that your workspace does have two parameters "path_1" and "path_2" (attention to case).
  • Apr 7, 2017 11:45 AM UTC
At first glance I see a non-terminated string literal on line 19. Is that a copy-paste error?
oscard
  • Apr 7, 2017 11:47 AM UTC
Yes, that's a copy-paste error. I wll edit it right away,
Thanks
  • Apr 7, 2017 12:01 PM UTC
You may have to urlencode the json string becore passing it into urllib2.Request, e.g.
import urllib
req = urllib2.Request(url, urllib.urlencode(body), headers)
Let me know if that makes a difference.
oscard
  • Apr 11, 2017 7:51 AM UTC
import urllib
With that code I get this error:
TypeError: not a valid non-string sequence or mapping object
  • Apr 11, 2017 8:00 AM UTC
params = {
            "name" : "path_1",
            "name" : "path_2",
oscard
  • Apr 11, 2017 8:13 AM UTC
params = {
            "name" : "path_1",
            "name" : "path_2",
Thanks to your comment I realized that path_1 is a list...
params = {
            "name" : "path_1",
            "value" : ["C://test1"]
            "name" : "path_2",
            "value" : "C://test2"
Thanks!!
