Publish workflows from GitHub to FME Server?
  • Nov 14, 2017 6:31 PM UTC
  • 82 views
fmelizard
Forum|alt.badge.img+22
A friend wants to know if we can publish workflows from GitHub to FME Server?
Best answer by fmelizard
This is a fantastic idea and one that is mentioned here (please add your comments):
https://knowledge.safe.com/idea/18790/workbench-connects-directly-to-revision-control.html
With the current FME Server Version Control functionality, our team shared that: pushing files from GitHub to FME Server (ie *pulling* from a remote Git) is not possible as of right now for a couple of reasons:
  1. We cannot bypass the Publishing Wizard which is responsible for dictating how FME Server will run the workspace (updating the database, registering services, allocated resources etc). In fact, a user can't just drop a workspace into the repository home folder which is what pulling does. FME Server will see that the workspace doesn't exist because the database does not contain that workspace.
  2. Pulling leaves the risk of merge conflicts which would require manually editing of the .fmw files which is obviously very difficult. More info here: https://www.git-tower.com/learn/git/ebook/en/command-line/advanced-topics/merge-conflicts
Right now FME Server allows *fetching* from a remote Git. Fetching simply retrieves the history without changing any files on FME Server.
fmelizard
  • Nov 14, 2017 6:33 PM UTC
