Projection System Conversion
parashari
Hi. I had a text file which had name, type and X, Y (coordinates in Lambert 72 projection).
I want to convert that projection (from meters) to WGS84. I have converted that input text file to csv file and tried Reprojector. But, the o/p I am getting is the same (no change). Am I on the right track ?
  • March 11, 2016
Hi
Have a look at the AttributeReprojector.
The Reprojector will only work on geometries, not attribute values.
David
parashari
  • March 11, 2016
david_r wrote:
Hi
David
Thanks @david_r
