Projection issue
  • Jul 2, 2018 2:36 PM UTC
  • 78 views
boubcher
Forum|alt.badge.img+11
Hello there
we get this shapefile, the project EPSG is correct but it not in the right location, it should show in Saudi Arabia
we used all reprojection transformer available but it didn't work anyway to fix it
The shapefile is only sample data from the WFS we are reading
Thanks
Best answer by takashi
Probably it's the same issue as this question: Reprojection not working
Try using the CoordinateSwapper to fix the data, following @DaveAtSafe's suggestion.
  • Jul 2, 2018 3:12 PM UTC
boubcher
  • Jul 3, 2018 6:17 AM UTC
@takashi
Thanks we did use the swapper and its working, we added also checking process with a bounding box of the city in case this happens with other features during the transformation process
Thanks again
