Project from LL-27 to EPSG 3857 Web Mercator
  • May 1, 2023 9:24 PM UTC
  • 111 views
messagemauri
FME Desktop 2021
Data Source is in LL-27
I get a lines dataset in LL-27 and points dataset in LL-27. My objective is to shows these lines and points on a Map that is in Web Mercator, EPSG:3857.
I currently use the CsmapReprojector and I have the following configuration:
Source Coordinate System: LL-27
Destination Coordinate System: EPSG: 3857
Transformation: NAD27_to_WGS84 (Multistep)
When I write the output for the lines and points to a Shapefile and place them in a Map in Web Mercator, the lines and points align and connect as expected, however, the problem is that their map positioning is slightly off from the actual Lat Long values that they should fall on.
Is there another 'Transformation' I should be using to get them properly positioned on the map (map in Web Mercator)?
Thanks for your time. Much appreciated.
daveatsafe
Forum|alt.badge.img+24
  • May 1, 2023 10:16 PM UTC
Hi @messagemauri​,
Your original lat/long values are in NAD27, while the lat/long values shown in the Map will be in WGS84, as used in EPSG:3857. Due to the different ellipsoids used by these datums, the lat/long values will be different.
messagemauri
  • May 1, 2023 11:39 PM UTC
Hi @messagemauri​,
@daveatsafe​  , Thank you very much for your reply and explanation.
