Produce an image (from vector and pointcloud) and link/embed it in a HTML report
  • May 6, 2021 12:49 PM UTC
  • 73 views
HI guys,
I am trying to create an image from vectors and point clouds, and later include it on an HTML report generator. After RasterExtractor and a BinaryEncoder, the HMLResportGenerator is unable to open the image file.
Do you have any suggestions?
Thank you!worspacefme
logfme
nielsgerrits
Forum|alt.badge.img+67
From the documentation:
...This parameter expects a valid path to a png or jpeg file. If setting this path from an attribute, the user must ensure that the image exists on disk at the time the features hit this transfomer...
So I think this wont work. You can choose custom HTML, so I think if you put something like
<img src="data:image/png;base64, iVBORw0KGgoAAAANSUhEUgAAAAUAAAAFCAYAAACNbyblAAAAHElEQVQI12P4//8/w38GIAXDIBKE0DHxgljNBAAO9TXL0Y4OHwAAAABJRU5ErkJggg==" alt="Red dot" />
it will work the way you need. Not tested but I expect this to work.
