Problems with SQL Statement and Access
  • Feb 20, 2020 11:11 AM UTC
  • 59 views
ann
I have a lot of shapefiles that I want to clip with different areas which I read from MSAcces and I want to select the area that I need for the certain shapfile and clip the shape-file. I use SQL Executor connected to a MS Access database to select the area that I want to use but I don't get the area. Do anyone have any solution?
Forum|alt.badge.img+63
How are the areas stored in Access and how have you set up the SQLExecutor?
@ann Is your MS Access file an Esri Personal Geodatabase? If it is then you can use the FME Geodatabase (MDB) reader. To do that you need a 32bit version of FME installed along with ArcGIS.
