Problems rotating tif files
I am attempting to rotate some tifs 90° using a rotator but it seems at the end they are still portrait, I get no error message, it seems to go through the rotator transformer just fine but my output is unchanged.
Am I using the right transformer?
The help seems to suggest that rotator can rotate raster images, Im just not sure why Im not seeing the effects.
Thanks
Jim
  • April 19, 2016
If I add an inspector after the rotation the tiff is rotated to landscape but the output file is still portrait...
jdh
Forum|alt.badge.img+41
  • April 19, 2016
Depending on your output format, you'll probably need to use a RasterRotationApplier after the Rotator
  • April 19, 2016
My output is tif, im resampling from 2400dpi to 1016 dpi then applying rotation to the ones that need to be landscape, i did try the RasterRotationApplier after rotator but after about 10 mins it had only got to 0.03%, I assumed it must be doing something else as rotation shouldnt take that long surely, I'll try that at work again tomorrow but it seems rather slow, I need to process around a 100 files a time so that would take days!
  • April 20, 2016
I tried this this morning, started processing at 9:36am, its now 10:41am and its showing 0.45% through intermediate processing and has been at that figure for the last 10 minutes, this is just one file, there must be a better way to rotate it than this. It spent an age optimizing memory usage before the intermediate processing.
  • April 20, 2016
Im wondering if 32bit windows issues is just causing it to not have enough memory to process, need to get onto a 64 bit and test.
jdh
  • April 20, 2016
Try a RasterCheckpointer after the Resampler to see if that improves performance. Also make sure you're only processing one file.
If you see the message optimizing memory resources, then switching to 64-bit will enable access to more RAM.
mark2atsafe
Forum|alt.badge.img+59
My thoughts are the same as jdh - try a RasterCheckPointer but also try to process only one raster at a time. If you are processing a whole bunch at once it will eat up memory very quickly. You can process one at a time by creating a master-child setup (the master workspace reads a list of files and runs the child workspace for each file using the workspaceRunner)
