Problem with WorkspaceRunner / Parameters > Undefined macro `xy' dereferenced
  • Nov 9, 2022 1:55 PM UTC
  • 66 views
vki
Forum|alt.badge.img+8
Hello
Somehow there seems to be a problem with the WorkspaceRunner and privateParameters in the Workspace, that should be run. .. (I use FMEDesktop 2022.1)
I get this error-message:
Undefined macro `Pfad_MGDM_Files' dereferenced in file `I:\\AGI\\Geoinformation\\Produkte\\GDI\\Themen\\A021 Laermempfindlichkeitsstufen\\c\\etl\\wb-xlate-1668001125589_14180'
> the Parameter `Pfad_MGDM_Files' is a private parameter in the Workspace to be run, and I use it, to concat a filepath.
A private parameter should be of no interest to the workspace with the WSRunner...?
I attach the workspace below.
Thanks in advance
Vera
vki
  • Nov 9, 2022 2:16 PM UTC
It works, if I concat the parameters in the workspace with the WorkspaceRunner and pass the concatenated path to the other workspace.
But shouldn't it work the way, I tried it at frist, too?
