Problem with SQL Server and special characters
  • Jun 8, 2022 9:24 AM UTC
  • 748 views
larsk
I am having problem writing attributes with swedish characters (åäö) to a mssql table.
The characters get replaced by other strange characters instead. I am using FME Desktop 2022.0.0.2 build 22343.
The database is set up with collation Finnish_Swedish_CI_AS as it should be.
Other programs such as QGis is writing åäö to the table correctly.
Is there some kind of setting that I need to do in FME or is this a bug?
Best answer by debbiatsafe
Hi @larsk​ ,
Thanks for letting us know! This behaviour is due to a bug that was fixed in FME 2022.0.1 build 22346. Installers can be found at https://www.safe.com/support/downloads/
If any users running into this issue are unable to upgrade to the build above or newer, please try one of the following workarounds:
  1. Disabling Bulk Inserts on the SQL Server writer
  2. Updating Microsoft OLE DB Driver for SQL Server to at least version 18.4 and ensure Use Unicode UTF-8 for worldwide language support is enabled on the Windows System Locale setting
  • Jun 8, 2022 11:08 AM UTC
My first recommendation would be to install the SQL Server ODBC driver, which FME should use automatically, when present. I believe it's much more recent than the 2012 Native Client installed with FME (unless something's changed in 2022).
https://docs.microsoft.com/en-us/sql/connect/odbc/download-odbc-driver-for-sql-server?view=sql-server-ver16
You'll need to restart FME after the installation.
larsk
  • Jun 8, 2022 11:38 AM UTC
That didn't help. But I tried the latest beta version and it works there so I guess it's a bug that is fixed in the latest beta.
Thanks anyway!
debbiatsafe
Forum|alt.badge.img+24
  • Jun 8, 2022 11:45 PM UTC
Hi @larsk​ ,
larsk
  • Jun 9, 2022 6:19 AM UTC
Thanks! Upgrading to the new version solved the problem.
