i would like to ask :
i want to snap several small lines to closet point ,i have around 20 point but i have problem with only 2 point .
each small lines connects to different lines around each point
First point : 6 lines around 1 point around 1.30 m
Second point : 5 lines around 1 point around 1.50 m
For First point : i used snapper but i got the problem ,i have to use maximum 1.3 because more than it ,it will snap the second line instead of the first line close to the point .
but i need to use value higher than 1.30 ,around 1.5 to snap the second point but it is not working well with the first point , because it snapped wrong lines .
i tried neighbor finder with generate list ,i found it gives me alll lines around it and each line that i have around this point small line connects to lone line and it give me each lines connected around this point .
i tried alot but i am not sure how could i manage snapping between this 2 points
FME Version 2018
Thanks in advance for any help
