Problem with "RasterCellCoercer"
  • Apr 27, 2017 4:56 PM UTC
  • 14 replies
  • 162 views
Dear FME-Users,
I've a problem with "RasterCellCoercer", because this transformer don't write pixel values into an attribute.
It only works with "RasterToPolygonCoercer" (attribute "_label").
What I'm doing wrong?
Thnak you very much and best regards.
Konrad
Best answer by uba_kp
Both does not work @itay @jdh . The attribute "_con" is still empty.
jdh
Forum|alt.badge.img+41
  • Apr 27, 2017 4:59 PM UTC
The rasterCellCoercer outputs a list, rather than an attribute, so depending on which band(s) you want the value from you can use a ListIndexer or ListConcatenator
  • Apr 27, 2017 5:13 PM UTC
Thank you @jdh, but both transformers does not work. Do you've some more ideas?
jdh
  • Apr 27, 2017 5:18 PM UTC
What exactly do you mean by does not work, are they throwing errors or not doing anything? Can you post some sample data or the results of a logger attached to the RasterCellCoercer?
itay
Forum|alt.badge.img+19
  • Apr 27, 2017 5:22 PM UTC
could it be that you are using the table view in the Data Inspector? have a look at the result via the feature information window, the table view does not show lists and its elements.
  • Apr 27, 2017 5:29 PM UTC
I've added to screenshots, take a look to the attachement please.
  • Apr 27, 2017 5:31 PM UTC
No I used ArcMap instead of Data Inspector.
itay
  • Apr 27, 2017 5:32 PM UTC
You need to connect the ports of the transformer to the writer (they become green) to write the values.
jdh
  • Apr 27, 2017 5:36 PM UTC
The ListConcatenator needs to come after the RasterCellCoercer.
  • Apr 27, 2017 5:42 PM UTC
jdh
  • Apr 27, 2017 5:45 PM UTC
Did you change the parameter on the ListConcatenator to point to _band{}.value ?
  • Apr 27, 2017 5:47 PM UTC
I don't know what you mean. I've added a screenshot of this transformer already.
jdh
  • Apr 27, 2017 5:51 PM UTC
And in the screenshot you posted, you are concatenating a list called netcdf_data_variable.valid_range{}, which presumably is empty since _con is empty.
You need to concatenate the list that is produced by the RasterCellCoercer which is called _band{}.value.
itay
  • Apr 27, 2017 5:54 PM UTC
And in addition make sure the writer data type and lenght is correctly set.
  • Apr 27, 2017 5:56 PM UTC
Now it works! :) Thank your very much @jdh and @itay!!!
