Problem with python start up script (engine reboot) & problem with subprocess work around
Hello - I am having problems executing a python process as a startup script - the script accesses a series of ArcGIS modelbuilder models & iterates through many processes and consistently fails at around the 50th iteration (engine reboots). I researched and found the below link that suggested calling python with a subprocess as a work around for this behaviour. However, I can't get the script to run using the method in link below....Any ideas?
http://fmepedia.safe.com/articles/Error_Unexpected_Behavior/Shutdown-Python-Script-Causing-FME-Engine-Failure
2013-06-06 10:56:13| 0.2| 0.2|INFORM|Feature Manipulation Engine 2012 SP4 (20120926 - Build 12266 - WIN32)
2013-06-06 10:56:13| 0.2| 0.0|INFORM|FME_HOME is 'C:\\apps\\FMEServer\\Server\\fme\\'
2013-06-06 10:56:13| 0.2| 0.0|INFORM|FME Engine (floating)
2013-06-06 10:56:13| 0.2| 0.0|INFORM|Permanent License.
2013-06-06 10:56:13| 0.2| 0.0|INFORM|Machine host name is: sxmcifme001
2013-06-06 10:56:13| 0.2| 0.0|INFORM|START - ProcessID: 6404, peak process memory usage: 29372 kB, current process memory usage: 29272 kB
2013-06-06 10:56:13| 0.2| 0.0|INFORM|FME Configuration: Command line arguments are `fme' `NRM ETL Testing\\eba_17_7_TRAILS_STAGE_PROCESS\\eba_17_7_TRAILS_STAGE_PROCESS.fmw' `--FME_DATA_REPOSITORY' `//ds.fs.fed.us/efs/FS/Reference/GeoTool/agency/EDW/FME12Repository//Server/Upload/' `--SourceDataset_SDE30_3' `AllTrails' `--FME_SERVER_NAME' `Engine2' `-FME_ENGINE_MEMORY_REDLINE' `0.5' `-FME_SHARED_RESOURCE_DIR' `\\\\ds.fs.fed.us\\efs\\FS\\Reference\\GeoTool\\agency\\EDW\\FME12Repository\\Server\\repository\\NRM ETL Testing\\fmeresources' `-LOG_FILENAME' `//ds.fs.fed.us/efs/FS/Reference/GeoTool/agency/EDW/FME12Repository//Logs/jobsubmitterservice\\FME_312E2A06_1370537773439_6404.log' `--FME_SERVER_ROOT' `//ds.fs.fed.us/efs/FS/Reference/GeoTool/agency/EDW/FME12Repository/' `--DestDataset_GEODATABASE_SDE' `AllTrails_SDO' `--FME_SECURITY_ROLES' `fmeadmin fmeauthor fmeuser' `--FME_MF_NAME' `eba_17_7_TRAILS_STAGE_PROCESS.fmw' `--FME_SECURITY_USER' `ebaiello'
2013-06-06 10:56:13| 0.3| 0.1|INFORM|Python version 2.6 successfully loaded
2013-06-06 10:56:14| 0.5| 0.1|INFORM|FME_BEGIN_PYTHON: evaluating python script from string...
2013-06-06 10:56:14| 0.5| 0.0|WARN |Python Exception <SyntaxError>: invalid syntax (<string>, line 1)
2013-06-06 10:56:14| 0.5| 0.0|ERROR |Error executing string `Import subprocess
subprocess.call(['C:\\\\Python26\\\\ArcGIS10.0\\\\python.exe','C:\\\\EDW_Tools\\\\Roads_Trails\\\\Python\\\\TrailsSegmentation_12.py'])
2013-06-06 10:56:14| 0.5| 0.0|ERROR |FME_BEGIN_PYTHON failed to execute provided script
2013-06-06 10:56:14| 0.5| 0.0|INFORM|FME Session Duration: 0.6 seconds. (CPU: 0.3s user, 0.2s system)
2013-06-06 10:56:14| 0.5| 0.0|INFORM|END - ProcessID: 6404, peak process memory usage: 36824 kB, current process memory usage: 36668 kB
could you please post your Python code here? It seems you have an invalid syntax somewhere, but it is difficult to tell when we can't see your code :-)
David
  • June 6, 2013
Hi David,
Here is the startup script calling sub process. And following that is the python script that does the work. Thanks for taking a look!
import subprocess
import pyfme
subprocess.call(['C:\\Python26\\ArcGIS10.0\\python.exe','//ds.fs.fed.us/EFS/FS/BusOps/CIO/Project/EDW/FME_Work/Roads_and_Trails/Processing_Tools/python/TrailsSegmentation_12.py'])
# Import arcpy module
import arcpy
import sys
import time
#Timer Object
from datetime import datetime
class TimerClass:
def __init__ (o):
o.sTime = datetime.now()
print "Timer Started at: " + str(o.sTime)
def pElapsed(o, text = ""):
dTime = datetime.now() - o.sTime
print text + str(dTime)
t = TimerClass()
dbConnections = "\\\\\\ds.fs.fed.us\\\\EFS\\\\FS\\\\BusOps\\\\CIO\\\\Project\\\\EDW\\\\FME_Work\\\\Roads_and_Trails\\\\Processing_Tools"
#dbConnections = "c:\\\\nrmpub\\\\additionalfiles\\\\roadsegmentation\\\\"
arcpy.env.workspace = dbConnections + "\\\\EDW_g_wo_nfs_eng_stage as fme.sde"
# Load required toolboxes
arcpy.ImportToolbox("\\\\\\ds.fs.fed.us\\\\EFS\\\\FS\\\\BusOps\\\\CIO\\\\Project\\\\EDW\\\\FME_Work\\\\Roads_and_Trails\\\\Processing_Tools\\\\EDW.tbx")
arcpy.gp.toolbox = "\\\\\\ds.fs.fed.us\\\\EFS\\\\FS\\\\BusOps\\\\CIO\\\\Project\\\\EDW\\\\FME_Work\\\\Roads_and_Trails\\\\Processing_Tools\\\\EDW.tbx";
#Empty AllTrails
arcpy.gp.EmptyAllTrails()
t.pElapsed("AllTrails features deleted : ")
tb = dbConnections + "\\\\EDW_g_wo_nfs_eng_stage as fme.sde\\\\EDW_SDE_SOURCE_CATALOG_V_temp"
rows = arcpy.SearchCursor(tb, "USE_IN_ETL = 'Y' AND SOURCE_FEATURE_CLASS = 'TRAIL'","","","schema")
lSchema = []
lForests = []
cnt = 0
for row in rows:
lSchema.append(row.schema)
lForests.append(row.forests)
cnt = cnt+1
del rows, row # Delete Cursor objects to remove locks
# Process Trails
for i in range(0,cnt):
print str(i) + " - " + lSchema[i] + " - " + lForests[i]
try:
if str(lForests[i]).find(",") == -1:
arcpy.gp.SegmentTrail(str(lForests[i]), str(lSchema[i]))
time.sleep (10)
t.pElapsed("processed "+ str(lSchema[i]) +" after : ")
#else:
fa = str(lForests[i]).split(',')
tq = ""
for j in range(0,len(fa)-1):
tq += "SECURITY_ID LIKE '" + fa[j] + "%' OR "
tq += "SECURITY_ID LIKE '" + fa[len(fa)-1] + "%' "
arcpy.gp.SegmentTrailCSA(tq, str(lSchema[i]))
print tq
t.pElapsed("processed CSA-"+ str(lSchema[i]) +" after : ")
except:
t.pElapsed(str(lSchema[i]) + " Failed after : ")
print "Unexpected error:", sys.exc_info()[1]
pass
t.pElapsed("Completed after : ")
what happens if you execute the Python script from the command line, e.g.
C:\\Python26\\ArcGIS10.0\\python.exe .../TrailsSegmentation_12.py
At first glance it looks like the error reported by FME is caused by your external Python script, not FME itself.
David
Also try to replace all your backslashes "\\" with forward slashes "/" in the command path:
From
To
'C:/Python26/ArcGIS10.0/python.exe'
Backslashes have a particular meaning in Python string literals, which can be confusing sometimes.
David
Hi,   and also check indentations in the actual code. There are no indentations in the code you posted, structured indentations are very important in the Python code, invalid indentation causes a syntax error.   Takashi
