Problem with ListExploder with Version FME Desktop 2024.0 (build 24187)
  • Mar 7, 2024 7:34 AM UTC
  • 6 replies
  • 296 views
gvenhorst
Have a workbench that I have been using for a while in previous version (2023).
This is to convert data with attachments from ArcGIS online to a FGDB.
I use a ListExploder for this, I don't get an error message but also no objects.
When I use the workbench again in the old version, everything works fine again.
The problem occurs when a space is used in the naming of the layer and/or feature class.
Does anyone know about this problem? Any solution would be helpful.
Gerard
hkingsbury
Forum|alt.badge.img+73
  • Mar 7, 2024 7:55 PM UTC
Could well be a bug. Have you tried recreating that part of the process in a fresh 2024 workbench?
Either way, worth opening a support case as it could be a bug that can be patched in a subsequent release
gvenhorst
  • Mar 8, 2024 5:49 AM UTC
Hi, I have indeed tested with a clean workbench in both the 2023 and the 2024 versions.
What struck me is that there is already a difference in the ArcGIS online reader.
In the 2024 version a " " is placed in the fields, possibly that is already the cause?
Version 2023 ArcGIS online reader.
Version 2024 ArcGIS online reader.
Gerard
hkingsbury
  • Mar 10, 2024 7:15 PM UTC
I wouldn’t worry too much about the double quotes, possible that the reader is a newer version in 2024
gvenhorst
  • Mar 11, 2024 7:07 AM UTC
If the " " are there, the reader does not work.
If I remove the " " itself, the ListExploder doesn't work.
hkingsbury
  • Mar 11, 2024 6:54 PM UTC
How do you mean the ListExploder doesn’t work? In inspector, is there a list attribute? (possible unexposed?)
gvenhorst
  • Mar 18, 2024 7:17 AM UTC
If you remove the " " in the AGO Feature Reader, the objects will be read, if you then start the ListExploder no objects will be loaded, there will be no error message.
