Problem with AutoCad blocks from donut geometry and polygons
  • Jan 27, 2023 11:21 AM UTC
  • 116 views
I am trying to combine symbols consisting of donuts and polygons into a DWG block. The problem is that the areas are displayed incorrectly in the DWG. With the option "Prefer writing donuts as hatches" set in the DWG Writer ( even in the RealDWG Writer) the symbols are displayed as follows.
The donut polygons are displayed correctly, the simple polygons only as a line. If I deactivate the option, all polygons are displayed as a line. The creation of the block is controlled by the attribute autocad_block_name.
Can someone help me? Thanks a lot
Edit: I also tried to generate the DWG from an Aggregrate
danilo_fme
Forum|alt.badge.img+58
  • Jan 27, 2023 12:19 PM UTC
Hi @fabian_do​
Please, could you share your data?
Thanks in Advance,
Danilo
  • Jan 30, 2023 12:02 PM UTC
Hi @fabian_do​
Thanks in Advance,
Danilo
Hi, here is a file with the described problem, generated from an Aggregate.
