I get the following message which I do not understand.
fme_expression_warnings{0}.message (string): Failed to evaluate expression '@DateTimeCreate(2018,11,5,6,9,14,0)'. Result is set to null
I tried filling the values as string values and converted to @int() and get the same result. Also tried with -0 as the last value.
