Problem with @DateTimeCreate function
  • Nov 8, 2018 12:56 AM UTC
  • 108 views
I get the following message which I do not understand.
fme_expression_warnings{0}.message (string): Failed to evaluate expression '@DateTimeCreate(2018,11,5,6,9,14,0)'. Result is set to null
I tried filling the values as string values and converted to @int() and get the same result. Also tried with -0 as the last value.
  • Nov 8, 2018 1:54 AM UTC
Check the warning shown in the log.
The syntax of a UTC offset must be (+|-)hh:mm, (+|-)hhmm, or (+|-)hh
  • Nov 8, 2018 1:56 AM UTC
See also here to learn more: Date/Time Functions
mark2atsafe
Forum|alt.badge.img+59
Like Takashi says, this should work:
@DateTimeCreate(2018,11,5,6,9,14,+0000)
Use an AttributePadder to pad to four zeros and the StringConcatenator (or AttributeManager) to add the + symbol
Thank you both. Two zeros already works.
