Problem using the FME Define custom Coordinate System Tool to define the ITRF 2014 Coordinate system
  • Sep 26, 2023 5:48 AM UTC
  • 83 views
bigcl
I am having problems using the FME Define custom Coordinate System Tool (demos-safe-software.fmecloud.com/fmedatastreaming/Coordsys/Start.fmw).
I want to make the ITRF2014 coordinate system that is in ESRI available in FME. I have used this ESRI WKT file from ITRF2014 - EPSG:9000 :
GEOGCS["ITRF2014",
DATUM["International_Terrestrial_Reference_Frame_2014",
SPHEROID["GRS_1980",6378137.0,298.257222101]],
PRIMEM["Greenwich",0.0],
UNIT["Degree",0.0174532925199433]]
However, when I test the new coordsys files I get errors.
Any help in tracking down what I am doing wrong would be greatly appreciated.
daveatsafe
Forum|alt.badge.img+24
  • Sep 26, 2023 9:45 PM UTC
Hi @bigcl​,
The coordinate system uses a datum that is not defined in FME, so it cannot presently be created using the online tool. I have manually created the definitions for the datum 'ITRF2014' and coordinate system 'LL-ITRF2014', in the attached zip file.
bigcl
  • Sep 26, 2023 10:55 PM UTC
Hi @bigcl​,
Awesome Dave - many thanks for that.
