Problem of crop a NetCDF file
  • Nov 22, 2024 2:03 PM UTC
  • 0 replies
  • 48 views
gjaguilar
Hello everyone.
I have a bug in a process that reads a NetCDF file and makes a Crop using a clipper transformer and then compare the result file with the original file using QGIS, compare point to point and some values ​​coincide but others, in the file result file do not coincide, it has a negative value and the difference between that value and the original file for the same point is a constant, for example in the result file the value is -0.588 and in the original file it is 0.436, the difference is 0.436- (-0.588) = 1,024.
The clipper parameters are like this
If someone has had this problem and can help me
Thanks in advance
