Problem installing Canada NTv2 grid files
  • Nov 15, 2019 1:04 AM UTC
  • 177 views
maphew
How to install NTv2 grid files?
Following the instructions at http://docs.safe.com/fme/2019.0/html/FME_Desktop_Documentation/FME_Workbench/Workbench/options_coordinate_systems.htm I've copied the `NTV2_0.GSB` file I acquired from NRCAN into "C:\\Program Files\\FME\\Reproject\\GridData\\NTv2".
From FME Options I select Coordinate Systems. Now what? Which of the listed items do I edit?
I tried NAD83_to_CSRS. I'm able to use the down arrow to select the NTV2_0.GSB file from previous step, but the [OK] button remains disabled.
maphew
Ok button solved. You need to delete the extra red rows.
(I didn't create them, they were there the first time I opened the Edit dialog)
maphew
  • Nov 15, 2019 5:07 PM UTC
After a nights sleep I realized NAD83_to_CSRS is the wrong selection for the NRCAN ntv2 files, they're meant for NAD27 to 83 transforms. However when I went to add it to NAD27_to_NAD83_Canada_FME instead I discovered the grid shift file was already there and set!
It would be nice if http://docs.safe.com/fme/2019.0/html/FME_Desktop_Documentation/FME_Workbench/CoordSys/Included_Grid_Shift_Files.htm were updated to reflect this. (The page does currently say NAD27<->NAD83 grid shift files are included, but doesn't say they are NTv2.)
nampreetatsafe
Forum|alt.badge.img+14
Hi @maphew: I'm sorry that it would have saved you time if we included the NTv2 info in the documentation. I've logged a request to our publications team about this suggestion. Thanks for your input!
