Problem by reading of HTML Table
Hello FME-Experts!
I have no experience with reading of html code, but I have problems reading data from a simple html file.
If I use the HTML Table reader I get only the first record (witch contain the attribute name of the data) and not the 4 records that I need.
I think, the workflow has to be simple but I tried several options without results.
I attach an html example file.
Thank you very much for the help!
Best answer by redgeographics
Okay, I finally figured it out. There was a similar question (same sample data actually) 2 weeks ago but I can't seem to find that one anymore. I do remember looking into it and being frustrated by it.
So the problem lies with the first row of your table:
<tr>
         <td><b>Nome_comune</b></td>
         <td><b>Numero_comune</b></td>
         <td><b>Numero_sezione</b></td>
         <td><b>Particella</b></td>
         <td><b>Superficie_m&#178</b></td>
         <td><b>Tipo</font></b></td>
         <td><b>Descrizione</b></td>
         <td><b>eGRID</b></td>
       </tr>
<tr>
There is a stray </font> tag on the Tipo line. That caused the HTMLTable reader to bork out after reading that first row.
So when I manually removed that tag it read 5 rows of data, the first one being the table header, but that got turned into a feature and was not used to populate the attribute names.
Changing the <td></td> tags in that first row to <th></th> tags (table data to table header) fixed that.
As for the solution... I don't think I have one to be honest. Both issues require pre-processing of the data, which isn't always feasible with HTML tables. I think your best bet is to submit an idea for 2 feature requests for the HTML Table reader:
  1. An optional parameter to ignore stray tags.
  2. An optional parameter to assume the first row of a table contains the column names.
Hope this helps. Not the answer you were looking for I'm afraid, but at least now we know what's the problem.
Forum|alt.badge.img+50
  • July 27, 2020
<tr>
       </tr>
<tr>
  • August 13, 2020
Thank you very much for your answer and help! I contacted the data producer and he removed the </font> tag. So I could read the data, skip the first line and add manually the attribute names. I added an idea for the feature request reading HTML tables.
  • August 16, 2020
For your information, you can use the HTMLToXHTMLConverter to clean up an HTML document containing a wrong syntax in some cases. In your case, the </font> tag without corresponding starting <font> would be removed if you applied the transformer. You can then parse the resulting XHTML document with the HTML Table reader.
mark2atsafe
Forum|alt.badge.img+49
  • August 17, 2020
I also created a bug report for our developers to look into this. It would be great if we could avoid failing in this scenario. fyi the reference number is FMEENGINE-66731
