PostGIS writer set to create if needed, still i get "table does not exist"
  • Mar 7, 2025 1:07 PM UTC
  • 6 replies
  • 122 views
so_much_more
I have a a workflow of moving several tables from one database to another one. I needed to make a change and wanted to test the workflow writing to my localhost instead of production database. So i changed the postgis writer from “Truncate existing” to “Create if needed” targeting my local test environemnt.
Still i get an error complaining that the tables does not exist?..
It does not matter if I hardcode the Table Qualifier or not. Or if i remove it all together.
I have tried to not running the wb in cached mode etc..
Tried running the WB in both 2023 version which it was created in and in 2024 version.
“POSTGIS Writer: Table 'rplan.PblMidlByggAnleggOmråde' does not exist. Please check the Table Name specified, or modify the Table Handling value under Format Parameters”
And yes the schema “rplan” does exisit in my localhost database.
I have no explanation to why FME would struggle with this?
Best answer by nielsgerrits
Just to be sure, you changed the table handling for all featuretypes, correct? Because the error is from the second table.
nielsgerrits
Forum|alt.badge.img+67
Does FME connects with an account which has proper rights? Can you create a table using this connection?
so_much_more
  • Mar 7, 2025 1:28 PM UTC
Yes i can. I tried writing tables dynamically from a bunch of shapefiles into a newly created schema in the same database. -Your standard postgres default database with the postgres superuser.
so_much_more
  • Mar 7, 2025 1:33 PM UTC
I did a test just setting up one reader and one writer to the same databse i am trying to write to above.
No issues…
With this one table created I ran the full workbench above and then it complained about the next table not already in the database. The workbench does not seem to pick up that the table handling parameter is changed.
nielsgerrits
so_much_more
  • Mar 7, 2025 1:55 PM UTC
Ooooohhh, ding ding ding! I completely overlooked that. My mindset was in the dynamic writer mode. You are completely right. It was set to truncate for the ones that was failing! Feel silly i overlooked that now! Thank you for spotting it, i was completely confused
nielsgerrits
Cheers :) I know the feeling.
