Hello, I am trying to generate dynamic POSGIS tables from spatialite data, however I cannot seem to force FME to create POSTGIS tables with Point / Line / Polygon geometric columns, they get forced to Geometry every time.
As you can see, I have geometry set from schema definition, I have disabled creation of generic geometry columns. My features look like this:
However when I look into the database, the table created looks like this:
SRID is generated correctly, but geom geometry(Geometry,5514) should be geom geometry(Polygon,5514)...
I have found similar question, from 7 years ago, is it possible that this has not been fixed? They are using feature writer, I am using normal writer.
PostgreSQL 13.10 on x86_64-pc-linux-gnu, compiled by gcc (Ubuntu 7.5.0-3ubuntu1~18.04) 7.5.0, 64-bit
FME: FME(R) 2022.0.0.2 (20220518 - Build 22343 - WIN64)
