Possible to use NeighbourFinder to calculate closest distance between points and lines with matching attributes?(One to one ratio)
  • Jun 19, 2019 7:08 AM UTC
  • 74 views
john_kohlin
Forum|alt.badge.img+7
I need to get the closest distance between points and lines calculated. The points and lines have matching attributes.
I only need distance calculated between point A and Line A, Point B and Line B.. Is it possible?
Forum|alt.badge.img+54
  • Jun 19, 2019 7:30 AM UTC
Yes, you can use your matching attributes as the group by parameter
john_kohlin
  • Jun 19, 2019 8:11 AM UTC
Thank you!
