Populate one attribute based on spatial overlap to existing attribute
  • November 25, 2013
  • 31 views
I'm trying to populate an attribute value from one feature to the next based what points are contained by certain areas.   I am using the SpatialRelator to find all my points that overlap my polygon, then I would like to map the value from my polygon onto the points existing Attirbute.   I have connected an AttributeValueMapper transformer to the output of my Spatial Relator but it does not seem to overwrite or transfer the attrubtes?
Example:
Point file
Attribute: Mapsheet
Polygon file
Attribute: WMS_Mapsheet
I would like to populate the Mapsheet attribute from the Polygons WMS_Mapsheet  based on the spatial relation the points are contained within the polygon.
  • November 26, 2013
Output features from the SpatialRelator will contain attributes of related CANDIDATE features as a complex list attribute named "_relationships" by default. For example, if you send points to BASE port and send polygons to CANDIDATE port, each output point will have "_relationships{}.WMS_Mapsheet" when one or more polygons are related spatially. Since output features also have "_related_candidates" (default name) attribute which indicates the number of related CANDIDATE features (0 or more), you can see how many CANDIDATE features are related with this attribute.
In addition, if a point cannot be related to multiple polygons simultaneously (in other words, polygons are not overlapped each other), you can also consider using the SpatialFilter.
Takashi
