Populate a sequence of XML elements with the contents of a list attribute
  • Dec 3, 2025 11:15 AM UTC
  • 171 views
steve.carroll
I am new to lists and xml in FME and having a bit of trouble. I am trying to use the XMLTemplater to populate an XML tag using a list value.
My XML template looks like this:
<prompt>{fme:get-attribute("prompt")}</prompt>
            <output>{fme:get-attribute("output")}</output>
            <data>
            for $testcount in fme:get-list-attribute("itemlist{}")
            return <item>{$testcount}</item>
            </data>
Test count is the output of a list element counter, and itemlist is a list attribute of the items.
My output looks like this:
<prompt>Material</prompt>
            <output>Survey Attributes/Material</output>
            <data>
            </data>
There are no contents being created within the data tag.
I am trying to get it to output like this:
            <data>
            <item>Concrete</item>
            <item>Steel</item>
            <item>Timber</item>
            </data>
The help guide gives an example of this:
<roads>
for $road_id in fme:get-list-attribute("road_ids{}")
return <road id="{$road_id}"/>
</roads>
I am just a bit confused what attributes get defined to make these list elements populate in the xml.
In the example, is $road_id a list element counter attribute, or is this something else?
Any help is appreciated.
Best answer by ebygomm
<data>
for $material in fme:get-list-attribute("itemlist{}")
return <item>{$material}</item>
</data>
Something like this should work
Although your example works for me too
Forum|alt.badge.img+54
  • Dec 3, 2025 2:13 PM UTC
<data>
</data>
steve.carroll
  • Dec 3, 2025 11:18 PM UTC
Thanks for your help.  I have got it working now.  I ended up needing to add ‘.item’ after the list attribute call.
Final XML template now looks like this:
<data>
for $material in fme:get-list-attribute("itemlist{}.item")
</data>
