Populate a field with distinct items when using concatenate in Aggregator
  • May 30, 2025 7:10 PM UTC
  • 135 views
rey
I am merging incoming attributes in Aggregator.  I concatenate the values from a field but I am getting duplicate values.  How do I create a cleaner attribute without duplicates?
  • May 30, 2025 9:14 PM UTC
Hi ​@rey ,
A solution I can think of is:
  1. Aggregator: Set the Generate List parameters to populate the values into a list, instead of setting the Attributes to Concatente parameter.
  2. ListDuplicateRemover: Remove duplicate values from the list.
  3. ListConcatenator: Cncatenate the list elements.
rey
  • Jun 2, 2025 2:14 PM UTC
Thanks. That was the approach I started to use after my post.
