Polygon shapefile - minimum width
  • Jan 9, 2019 3:05 PM UTC
  • 51 views
Hi, I have a shapefile that contains polygons and we would like to find the minimum width of each of the polygons. Any help would be greatly appreciated. Thank you.
gio
Forum|alt.badge.img+15
  • Jan 9, 2019 4:08 PM UTC
you could try create centerlines (can crash on complex shapes and donuts etc. ). Clean em up.
Chop by 2. Rotate pieces by 90 and then extend the line both sides by a sufficient large amount.
Line on area, clipper etc. Add length value.
Statistics calculator on length value grouped by object id.
jkr_wrk
Forum|alt.badge.img+37
  • Jan 10, 2019 10:23 AM UTC
You can get an indication of the width by dividing the area by the circumference.
