Polygon Grid Labeling
  • Jul 14, 2019 9:55 PM UTC
  • 111 views
Morning All, I have 4 equal polygons next to each other and i need to label them A,B C,B. Im struggling with my lists. They currently have no attributes My approach is to create a center point for all of them, to get the x and y. Then A should be the one with the smallest X and smallest Y, then B should be the Largest X and smallest Y etc etc. i get the inside x,y for all then build a list from them then sort the list by inside x but struggle from here. im unsure how to a list by two values ,ie x and y. i have tried list indexer, list exploder.
Thanks Steve point for each polygon then look for the [polygon with the smallest X and Y, this = A, The smallest X and
Best answer by jdh
What about Aggregator -> BoundsExtractor -> Deaggregator then AttributeCreator with conditionals to test if the individual polygon's upper left coordinate matches the extracted upper left.
If both A, If Y only B, if X only C if neither D.
jdh
Forum|alt.badge.img+41
  • Jul 15, 2019 1:40 AM UTC
  • Jul 15, 2019 9:10 PM UTC
Many Thanks jdh, thats just what i needed. I new the math i was after but didn't know the implementation. Thanks again, Steve
