Polygon georeferencer - AffineWarper
  • February 11, 2019
  • 54 views
piotrek6116
Hello FME members,
I try to marage two polygons ech other, but system coordinate is unknown (Left polygon). I try AffineWarper but reports empty output (it does not work). Another "trans" what i tested it's RubberSheeter, but coordinate system results not changed.
How to reproject polygons like "georeferencer" tool and saving information at attribute field: (angle, scale, rotation) in FME?
FME ver. 2018.1
PS: I found the solution in QGIS VectorBender tool.
virtualcitymatt
Forum|alt.badge.img+47
As a first test try setting your source coordinate system to 'EPSG:2180' and then use a reprojector to 'EPSG:2177'. Going on the coordinates it's possible that the source data is in this projection: https://epsg.io/2180, it might not work but it could be the easy way
piotrek6116
  • February 11, 2019
Thanks for answer, but definitely not. Because other polygons coordinate starts at (0,0).
