points intersecting buffers
  • February 13, 2015
  • 81 views
Okay I thought this was going to be easy but I'm just not getting how to do this. I have a CSV that I have used to create points and from there I have made 10 mile buffers. I have another reader from SDE that is also a series of points. What I am trying to do is to find only the points that intersect the newly created buffers. I hope that is clear enough to understand..
SDE ---- >tester oklahoma only--->-----------------------------------------\\
        \\-->sde intersecting points
CSV ---- >tester oklahoma only--->point adder off xy ---> buffer --\\
more or less that^
I would connect the two features to a PointonAreaOverlayer (http://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_Desktop_Help.htm#../Subsystems/FME_Transformers/Content/Transformers/pointonareaoverlayer.htm%3FTocPath%3DFME%2520Transformers%7CGeometric%2520Operators%7C_____18" target="_blank) transformer. The features you buffered would go the Area input port and the points you want to test go to the Point input port.
Read up on the documentation if you want to get fancy with lists.
  • February 14, 2015
Have u seen the SpatialFilter Transformer ???
This should help with your task
Feed in your datasets then set the operation mode eg
Intersect
Contains
Within
Overlap
etc
Also check out the Help for this Transformer (Help btn in dialog box or Help panel when Transformer is selected) - really useful.
Help shows some really good pictures which explain what each operation mode does
Hope this helps
Howard L'
  • February 16, 2015
Thanks for the replies I was able to get the SpatialFilter transformer to work for me.
