points in polygones
  • Jun 5, 2019 1:54 PM UTC
  • 9 replies
  • 127 views
terezia86
HI, I need to filter/select the points which are in the polygones.
I have many points and a 35 polygons. The result should be 35 layers of polygones in which will be this points which are overlaping polygons. I tried to do it with PointOnAreaOverlayer, but it does not work how I want to. I tried it now only with 3 Polygones. The reprojecting system is ok, and they are overlaping. As a result I get separate polygone and points-which is the same result as at the beginning. How to merge this points and polygones together?
The result:
Best answer by takashi
In my quick test, the points have been separated into three groups - points in group A are within the area of "Rheinland-Pfalz", B are within "Hessen" and C are within "Nordrhein-Westfalen", as shown in the screenshot below.
Do you need to write the point features into three Shapefile files (named A, B, C for example) for each group separately?
danilo_fme
Forum|alt.badge.img+58
  • Jun 5, 2019 2:25 PM UTC
Hi @tereziastredna
Could you send the Workspace template ( .fmwt )?
Thanks,
Danilo
terezia86
  • Jun 5, 2019 2:45 PM UTC
danilo_fme
  • Jun 5, 2019 3:02 PM UTC
Thanks your Template file.
I selected the transformer PointOnAreaOverlayer with create a List of attributes - all points inside the polygon:
Do you need all attributes from points?
I did run the Workspace and checked just a polygon with list of attributes from points inside the selected polygon:
Thanks,
Danilo
terezia86
  • Jun 5, 2019 5:06 PM UTC
Thanks,
Danilo
thanks for reply.
Yes, I need all of attributes which are there.
Ok I can see in list of polygone the number of _overlaps. Can I get the layer of theese points?
Acctualy what I need is to have a Polygone layer and the points- layer which are inside of this polygone. Not together if possible
Thanks
danilo_fme
  • Jun 5, 2019 5:34 PM UTC
thanks for reply.
Thanks
Hi @tereziastredna
About to have layer Polygon and Points on the same Writer is possible, but in Shapefile is not possible - is a restriction by Shapefile format.
Maybe Geodatabase.
terezia86
  • Jun 6, 2019 6:26 AM UTC
Hi @tereziastredna
Maybe Geodatabase.
ok I understand.
Is there maybe another option how to get theese point layer?
maybe with a different transformers? I would preffer to have a points layer.
  • Jun 6, 2019 9:02 AM UTC
terezia86
  • Jun 6, 2019 9:19 AM UTC
Hello @takashi.
Thanks for your help.
Yes that is exactly what I would like to have.
  • Jun 6, 2019 9:24 AM UTC
I think "Feature Type Fanout" is what you are looking for. See here to learn more.
https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_Workbench/Workbench/Setting_Feature_Type_Fanout_Properties.htm
