PointOnLineOverlayer - No Split Lines?
  • November 15, 2022
  • 47 views
vxn43
Forum|alt.badge.img+18
Wondering what parameter to change so that when I use PointOnLineOverlayer it does not split the lines? is this possible?
Best answer by redgeographics
Not with the PointOnLineOverlayer, but you can use the SpatialFilter and/or SpatialRelator instead.
Forum|alt.badge.img+62
  • November 16, 2022
