Pointcloud and Joint spatially
  • Jun 17, 2019 7:32 PM UTC
  • 120 views
arthy
Forum|alt.badge.img+8
Hello,
I would like to merge pointcloud data spatially.
To do that, I create polygons representing the hull of point cloud data using the following steps:
  • coerce point cloud data to individiual points,
  • Bufferer every individiual point
  • Dissolve the buffers that overlaps/intersects
  • Create a polygon using hull replacer
How can I perform such operation without using a pointcloudCoercer because it is too much time consuming.
Any idea on how to improve this part of my workbench?
Thanks
Best answer by takashi
I don't think there is so efficient way, but a better way at least than the PointCloudCoercer is:
  1. NumericRasterizer (Size Specification: CellSize): Transform the point cloud to a numeric raster, filling background with Nodata.
  2. RasterExtentsCoercer (Extents Type: Data Extents): Transform the data existing areas of the raster to a multiarea.
  3. Deaggregator: Decompose the multiarea into individual polygons.
  4. Clipper: Clip the original point cloud by the polygons (i.e. separate the point cloud into groups).
  5. HullReplacer: Transform the clipped point clouds to hull polygons.
  6. Bufferer: Make buffers from the polygons if necessary.
arthy
  • Jun 17, 2019 8:30 PM UTC
From this,
I would like to be able to obtain
@takashi and others, any ideas?
  • Jun 18, 2019 7:40 AM UTC
From this,
Is the source dataset is a single point cloud and do you need to separate the points within the point cloud into some groups according spatial proximity?
arthy
  • Jun 18, 2019 9:33 AM UTC
Correct @takashi. The data source is a single point cloud.
  • Jun 18, 2019 10:00 AM UTC
