Point Isolator
I'm new to FME and I’m reading in a CSV file then using 3DPointAdder. Now I need to isolate points that are divisible evenly by 0.25 so I can add a constant to the Z value then merge them back with the other points to create a new CCV file. Please Help. THANKS
