Point in Polygon query
  • Jun 10, 2019 5:50 PM UTC
  • 5 replies
  • 136 views
sunsilk11
Hi I have a point and polygon feature class.
I need to find out the ids of polygons which contains greater or equal to than specified numbers of points. Also I need to get the point attributes for each of these polygons.
The number of points are defined in an xml file (see attached). I will need to create an alert record in a table when the number of point reaches the defined count values.
Any suggestions ?
testconfig.xml
erik_jan
Forum|alt.badge.img+26
  • Jun 10, 2019 6:02 PM UTC
I would start by using the PointonAreaOverlayer transformer. This adds a list of attributes from the points on the area and an _overlaps attribute with the number of points per area.
sunsilk11
  • Jun 10, 2019 7:57 PM UTC
Thanks. But thos doesnt provide me the flecibility to join with xml file and what I need.
erik_jan
  • Jun 10, 2019 8:01 PM UTC
No, for that you will need to read the XML (XML reader) and a FeatureMerger transformer.
Then use the Tester to compare the values.
Hope this helps.
sunsilk11
  • Jun 10, 2019 8:31 PM UTC
  1. ok. _overlaps gives the count per polygon. but I also need the list of points for each polygon. Any idea?
erik_jan
  • Jun 10, 2019 9:19 PM UTC
The PointonAreaOverlayer allows you to define a list to store the attributes of the points that are inside the area. Have a look at the documentation for the transformer here
