Point in polygon atributes
  • Aug 7, 2018 11:25 PM UTC
  • 65 views
mr_fme
Forum|alt.badge.img+9
I need to use a transformer so I can have as output the attributes all together, the points that are inside a polygon, which ones I may be using?
Best answer by danilo_fme
Hi @mr_fme
did you try to use the transformer PointOnAreaOverlayer?
Thanks,
Danilo
danilo_fme
Forum|alt.badge.img+58
  • Aug 7, 2018 11:38 PM UTC
Hi @mr_fme
Thanks,
Danilo
mr_fme
  • Aug 7, 2018 11:41 PM UTC
Hi @mr_fme
Thanks,
Danilo
Yes, but I wouldn´t like to use this transformer. I need of the others options.
  • Aug 8, 2018 12:22 AM UTC
Hi @mr_fme
Thanks,
Danilo
The SpatialRelator could be another option. If the polygons don't overlap each other, the Clipper or the SpatialFilter could also be choices. But why wouldn't you like to use the PointOnAreaOverlayer?
mr_fme
  • Aug 8, 2018 1:00 AM UTC
I like to use SpatialRelator than the others choices. But I was thinked that can´t merge the attributes with SpatialRelator.
Thank´s a lot
