point at intersection
  • Jan 22, 2018 10:47 AM UTC
  • 9 replies
  • 241 views
nath
Forum|alt.badge.img+7
I have two polygon layers where de boundaries doesnt match. I need to add a vertex at each place where the two boundaries intersects. Is there an easy way to do this? I'm trying differents things but i haven't found the right way.
Thx
  • Jan 22, 2018 10:52 AM UTC
Have you tried the Intersector? You'll want the Node features.
Example:
nath
  • Jan 22, 2018 10:59 AM UTC
Yes i did but i'll get al lot of nodes, not only at the intersections. So i'm currently trying to filter out the nodes on the intersections by a spatial filter and then use the vertex creator to add a vertex at that point in the polygon shape. But it doesn't seem to work very well.
  • Jan 22, 2018 11:01 AM UTC
That sounds strange. Could you post an example (screendump or sample dataset) here?
nath
  • Jan 22, 2018 11:13 AM UTC
This is my first model, very simple. I just want a node where there is an intersection between the tho layers with polygons
nath
  • Jan 22, 2018 11:17 AM UTC
This is the result
  • Jan 22, 2018 11:19 AM UTC
This is the result
It's difficult to see what's going on here, could you post a screenshot zoomed in on two polygons, and also include the polygons themselves?
nath
  • Jan 22, 2018 11:28 AM UTC
The thick lines (zgb) is the layer where I want to add the vertexes where he crosses the thin lines (gemeenten). But I also get nodes where they do not cross each other.
nath
  • Jan 22, 2018 11:39 AM UTC
zcartografiewerkmappenaalstnathalie2018fmeprobleem.zip My data is to large, i have extract a sample
  • Jan 22, 2018 12:04 PM UTC
It looks like you have several polygons that overlap but with tiny imperfections (probably due to different tolerances and/or number of significant digits), which in turn creates a lot of "faulty" intersections. You'll probably have to clean up your data somewhat before calculating the intersections.
One solution could be to use a Snapper (mode "segment snapping" and with a tolerance of e.g. 0.01) on both datasets. This results in 311 nodes on your sample dataset:
An alternative could be to use the FME 2018 beta (download here) which has a tolerance setting in the Intersector.
