Please Help.....Domain Code Values
I am using Data Interoperability and "trying" to create a CAD (dwg) to FGDB workspace to use on all new projects that are submitted to us from a surveyor. I am on week 4 now so still pretty green to this software but do know the power it has once it is working correctly. We require the surveyor to submit an excel table that has all utility info (i.e., valves, tees, bends...) with the feature_ID as the database "key" to join to the .dwg. The problem I am having is finding the best way to convert the excel attributes to the coded domains in the existing FGDB. For example 8"x6" (excel table) is = to 78 in the code value in the geodatabase. What would be the cleanest way to make this conversion? AttributeCopier? This is the last step in my workspace and kind of lost. Thanks in advance for those able to help.
Login to the community
No account yet? Create an account
An FME Account is required to contribute
LoginEnter your E-mail address. We'll send you an e-mail with instructions to reset your password.
