Pivoting a table with new field names based on attribute values
  • Sep 19, 2019 10:02 AM UTC
  • 87 views
robinb
Hello all,
Can anyone help me in transforming my feature schema as per the included screenshot? I need to create new field names based on distinct data values held within the existing ‘Attr_Type’ field, and then populate these new fields with the relevant ‘Attr_Value’ value.
I’m using FME Desktop v2019.0.2
TIA,
RB
danilo_fme
Forum|alt.badge.img+58
  • Sep 21, 2019 2:05 AM UTC
Hi @robinb
I tested here in my computer your support.
For the solve this, I used just a transformer AttributeManager.
Inside this transformer I configurated like bellow:
As you can check the Workspace template ( attached ), I search for the values from attributees A,B,C - and set the attribute value = Attr_Value.
The result:
Thanks in Advance Workspace_Xls.fmwt
Danilo
robinb
  • Sep 23, 2019 8:32 AM UTC
Hi @robinb
The result:
Danilo
Thanks @danilo_fme - that has got me forward to the next step.
