PDF reader characters
  • Mar 6, 2019 4:07 PM UTC
  • 77 views
oliver.morris
Forum|alt.badge.img+14
Hi, I am reading text from a pdf using the PDF reader and in the text I see xEF, xBF, xBE - what are these and how do I remove them.
Thank you
danilo_fme
Forum|alt.badge.img+58
  • Mar 6, 2019 5:42 PM UTC
Hi @olivermorris
Could you share a amount of this information?
Thanks,
Danilo
  • Mar 7, 2019 8:25 AM UTC
It could be either non-printable characters or unicode characters that aren't encodable in the active encoding. xEF could e.g. be an ï (letter i with diaeresis): http://www.fileformat.info/info/unicode/char/ef/index.htm
But without knowing the context it's hard to be certain.
You could try using an AttributeEncoder to see if that gives you the expected result.
oliver.morris
  • Mar 7, 2019 10:38 AM UTC
Thanks for the help, an example below.I had some more of a search around and after adding:
String replacer and copying the black sections to replace they then were removed. As @david_r suggests I think they are just non printable characters.
All sorted, thanks
