Paste aggregator result into JSON attributes
  • Feb 7, 2019 3:08 PM UTC
  • 59 views
Hello,
I'm new to FME and I'm looking to get a JSON file formatted like this :
    "depart": {
        "INCENDIE" : 533,
        "AUTRES" : 30,
        "RISQUES TECHNOLOGIQUES" : 71,
        "OPERATIONS DIVERSES" : 320,
        "ACCIDENT" : 411,
        "SECOURS A PERSONNE" : 3813
The data comes from the following treatment :
And the inspector give me that informations :
I've try to use the following treatment :
With that configuration :
But I can not get the desired result as above.
If anyone could help me ...?
Best regards.
Best answer by takashi
This workflow might help you.
Root Template:
    "depart" : {|
        fme:process-features("SUB")
SUB Template:
{fme:get-attribute("MOTIF_DEPART") : fme:get-attribute("VAL")}
  • Feb 7, 2019 3:31 PM UTC
Root Template:
    "depart" : {|
SUB Template:
Thanks a lot, i get the expected result now.
Best regards !
