Passing *Multiple* Published Parameter from the Command Line
  • Aug 21, 2013 7:13 AM UTC
  • 5 replies
  • 83 views
robertr
Hello,
To state it clearly, currently I am passing a set of values:
--name Robert --city Calgary
I have to do this for multiple names and cities. How can I pass multiple names and cities into one command line so fme would take them one by one. Somthing like
--name "Robert" "David" "Marc" "Jason" --city "Calgary" "El Paso" "Indy" "Vegas"
The expected outcome should be to run the workbench with the values: Robert - Calgary, then with David - El Paso and so on.
I am trying to find an easy sollution to cope with this situation. Currently I am waiting for one to finish, then I add the next one and so on.
  • Aug 21, 2013 8:41 AM UTC
Hi Robert,
FME will not automatically iterate over a list of values like this, you will have to implement the iteration yourself.
One way could be to pass all the city names into one string with a suitable separator, e.g.
--city "Calgary;El Paso;Indy;Las Vegas"
You could then use an AttributeSplitter on ";" to create a list of all the city names before you treat them further, for example with a WorkspaceRunner.
David
robertr
  • Aug 21, 2013 10:00 AM UTC
Hello all,
Ok, it seems I really need to figure out this workspace runner thing. I kept avoiding it but it seems really useful.
Can you provide me a link where it is well explained and maybe I have an example of its usefulness using published params from command line?
Thanks guys,
  • Aug 21, 2013 10:44 AM UTC
Hi Robert,
the WorkspaceRunner is really very simple. It is nothing more than a transformer that enables you to run another workspace.
Have a look here:
http://docs.safe.com/fme/html/FME_Transformers/Default.htm#Transformers/workspacerunner.htm
David
  • Aug 21, 2013 11:57 AM UTC
Yes, usage of the WorkspaceRunner itself is very simple. I agree with David on this point.
But in this case, I think you need to create features having a pair of name and city as its attributes before applying the WorkspaceRunner. It might be a little complicated.
This image is just an example, please customize to your actual situation.
Assume the main workspace has two published parameters - "NAME" and "CITY".
Takashi
  • Aug 21, 2013 12:22 PM UTC
P.S. By the way, do you absolutely need to pass names and cities to the workspace via command line?
If I were you, I would consider another approach. That is to create a table having two columns (name and city), and pass the table file path to the workspace.
Takashi
