passing color rgb to pdfstyler
  • Nov 26, 2019 5:29 PM UTC
  • 8 replies
  • 165 views
tnarladni
Forum|alt.badge.img+24
I am creating a legend for my pdf and using the PDFStyler to create the different line colors. Based on a certain value in an attribute, I am setting the rgb for the legend line. It looks ok in inspector after the PDFStyler, but when it goes through the PDFPageFormatter, all the lines are blue. If I were to set the color for the data individually, it is fine, it is just when I attempt to set the color from an attribute that it doesn't work. Would appreciate any help.
some of the types are not defined which is why they are black.all blue
Best answer by ebygomm
If you already have the colours as RGB values, you can convert. There are custom transformers on the hub that will do this conversion for you, e.g. ColorCalculator
If you want to pick colours, this site will give you fme colours
https://www.tydac.ch/color/
Forum|alt.badge.img+54
  • Nov 26, 2019 5:56 PM UTC
I think the attributes need to be structured as FME colours not RGB if you are using the attributes to set the colour in the pdf styler, despite it displaying an RGB colour if you use the colour picker.
tnarladni
  • Nov 26, 2019 6:54 PM UTC
@ebygomm what's an fme color? how do I set that?
  • Nov 26, 2019 7:01 PM UTC
So the RGB colour for red is 255,0,0
FME colour for red is 1,0,0
White is 1,1,1
Black is 0,0,0
etc.
tnarladni
  • Nov 26, 2019 7:04 PM UTC
White is 1,1,1
Black is 0,0,0
etc.
do you have a link to a help? I need more than the basic colors...like cyan and magenta. thanks!
tnarladni
  • Nov 26, 2019 7:12 PM UTC
tnarladni
  • Nov 26, 2019 7:18 PM UTC
could you post this as an answer? so I can accept it? And thanks. that was super helpful. Also, I found that if I divide the R G B color by the full saturation 255, I get the RGB FME value
