Parsing ZIP-file with multiple file-types on FME Server
  • May 15, 2014 7:23 PM UTC
  • 101 views
Hi!
I have a zip-file (attached) that I want to parse with a workspace on FME Server. I want to use an Excel reader to read the Excel-file in the ZIP, then if the Shape-file column in the Excel-sheet contains a file-name I want to use the FeatureReader to read the Shape-file (which lies in a known sub-dir). The Excel file reads fine, but I can’t seem to produce the right path to pull up the Shape-file..?  The trouble I’m having is producing the temporary path to the Upload service, including the sessionID and the ZIP-file “directory”?? Any help would be appreciated.
https://dl.dropboxusercontent.com/u/44513131/DATAPAKKE.zip
[Above is the ZIP-file I'm using for testing]
  • May 16, 2014 8:03 AM UTC
I can't get FME 2014 SP1 to read it properly either, unless I first delete the Excel-file from the zip archive.
You might be better off using a WorkspaceRunner with a separate workspace rather than the FeatureReader.
You might also want to send your zip-file to your reseller (or Safe) to see if this is an intended "feature" or a bug.
Lykke til.
David
  • May 16, 2014 8:05 AM UTC
Or, for FME Server, the FMEServerWorkspaceRunner...
David
  • May 16, 2014 8:42 AM UTC
Got this reply from Safe Software Support (De Wet van Niekerk) which solved the case:
I would recommend not supplying the path to the Excel file directly, but rather the path to the zipfile as a publishe parameter INPUT_ZIPFILE of type "File (Existing)". Then, build up the path to the Excel file as follows:
$(INPUT_ZIPFILE)/*/*.xlsx
Read the value from the Excel file, and then you can build up the shapefile path as follows in an AttributeCreator:
$(INPUT_ZIPFILE)/*/@Value(InternID GU)/GU_flate/@Value(Shapefil-navn)
